ceiling attributes
KyleHepp
ceiling attributes
Post by KyleHepp »
Case in point, I'm laying out rooms for closet cabinetry. I have attic access panels in two of the rooms and would like to add the scuttle-holes + their swing down areas to the design to illustrate what can and can't be placed. How is this done?
Michael Yeargain
Post by Michael Yeargain »
Kyle Hepp,
I don't know if this is what you are talking about but the images here show an area somewhat highlighted by a glass textured display cube.
Simply create a display cube the size indicative of the area you want to display and load a glass from the display items, and match the texture.
Hope this helps.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
KyleHepp
Post by KyleHepp »
For quick & dirty, that works. Is there a way to make an actual ceiling, edit ceiling and insert items into that ceiling (eg. door/jamb/casing)
I'm wondering if the \"Z\" axis might allow for this?
Kyle,
You can use a Display Cube for your ceiling and the things you want but it creates some problems when lighting the room.
Attic Steps
He are attic steps I made for my son's house in 2005.
Master closet They are not the cabinets we made for the room.
My son wanted to know why I did not put the trim on the ceiling around the opening :twisted:
Here are just the attic steps in zip file
Ceiling opening (R)25\" x 54 1/2\"
Steps 24 1/2\" x 54 x 3 1/2\" x 61\"Out on floor 8' High
Attic Done 24.625 x 54D x 8 Ft.zip
(215.61 KiB) Downloaded 491 times
KyleHepp
Post by KyleHepp »
So that is done in a \"display cube\"?
That is a perfect example of what I need to place into my design layout.
Can you set this to illustrate exactly where the door and stair swings? (or where a typical passage door OR cabinet door would swing) for the purpose of designing with respect to hardware parameters (110deg/170 deg hinges), adjascent item placement, etc...
Hi Kyle
I made it out of
A-Steps out of one cabinet
B- Door out of one cabinet
C-Rail out of a display cube
If you down load the zip file it will be all in there
