Need some help with a drawing that will not fully render
JohnLashuay
Post by JohnLashuay »
attached is the file that I am trying to render. It only renders about a third of the way and then the bottom 2/3 it renders black.
Does anyone have any ideas??
John
P.S. I am using 5.1.3
John,
I have this happen a lot. Look where the drawing stops rendering, it is probably at a pull or a rope molding or something else that is causing an overload. I get around it sometimes by saving the job then completely shutting down the computer (not just a re-start) then upon starting the computer up again go immediately to your render and try it while the computer still has a lot of resources. If it still hangs at that spot, remove the pull or molding that is causing it.
JohnLashuay
Thanks Kerry for the help. It worked!!
John
