Hi guys, Ever since I've upgraded to V3 I have been unable to shut ecabs down normally via the File...Exit. I'm having to use Ctrl-Alt-Del to shut the program down. It keeps giving me the same error every time
Unrecognized database format 'c:\\program files\\thermwood\\ecabinet systems\\DOORS\\Conestogaz\\zigaba.twt'.
Any suggestions? I started the V3 install sequence, but stopped when it said it was going to remove it. I guess I should attempt to remove it and then reinstall.... I'm also getting this when I attempt to nest and it never even gets to nest the parts.
Problem solved!! So far at least. I uninstalled Build 3, reinstalled Build 3, rebooted the computer, and wham..... no more error messages. I can shut ecabs down normally, and nest without any error messages. Now....back to work.
