Using splines in the shape manager
Roger Erismann
Post by Roger Erismann »
I was trying to use splines in the shape manager and then import the geometry to the parts editor....
A couple of things are going on:
Splines won't extend or trim
After I save the geometry only a portion of it shows up in the parts editor
[/list]
Wood Butcher/Case Maker
Roger,
I might be wrong but I don't think splines work in the Part Editor, they must be converted to a series of arcs. You can create a tool using splines in the Shape Manager and the tool will work in the Part Editor but the geometry won't.
Al Navas
Post by Al Navas »
Roger,
Apparently, the spline tool does not work properly within eCabs, as it is not supported in the program. I found several threads that address this issue. Click on the links:
1. Use 3-point arcs to recreate a spline.
2. More of the same, using 3-point arcs.
3. And the one thread that states that splines are not supported.
You might want to try using 3-point arcs to create the curves you need.
Al
http://sandal-woodsblog.com
Sebastien Boileau
Post by Sebastien Boileau »
I found a utility addon for autocad it's called \"splineConvert\" it does what the name says, convert's splines into arcs so it can now be imported to the shape manager, here's the link:
http://www.xanadu.cz/en/download.asp?fi ... ,%20trial)
Enjoy!
