applying molding
peter keiser
applying molding
Post by peter keiser »
i have designed a hearth type range hood around a standard wall cabinet using display cubes and custom door panels and associated every piece to the cabinet , but when i try to go the molding editor the system goes back to the standard wall cabinet i started with.. wassuup
Peter,
The molding editor will always just place molding on your original cabinet. You will have to place the moldings manually as display parts using the Cabinet/Assembly Editor
