error verifying tool path
Ray Jorgensen
Post by Ray Jorgensen »
Here's a profile that I have 60' of to run. I get a error when I try to verify the tool path. Any suggestions?
problem files.zip
(248.71 KiB) Downloaded 414 times
Daniel Vonderheide
Post by Daniel Vonderheide »
Ray,
If you change the plunge depth on your tool from .75 to .749 it works. I have seen this before, when the tool is removing all the material under the flat center section, it can cause errors.
Ray Jorgensen
Thanks Dan - I'll give it a try in just a little while. Then let you know the outcome.
