Can't save (hoops fatal error)
wayne chater
Post by wayne chater »
I build my room (with c-tops) and save it just fine. I then bring it to line drawing editor to produce shop drawings, make one copy which I turn for a front view, try to save and get hung up. I eventually get the following message;
Hoops fatal error
Fatal error (3/4) from hoops routine 'copy segment'
no more memory available.
I have an intel E6600 core 2 duo 2.40 GHz, 300 GB hd drv w/ 2GB ram.
Anyone know what's going on?
Thanks, Wayne
Walker T Scott
Post by Walker T Scott »
wayne
Can you attach the room so we can take a look at it?
Walker
wayne chater
file attatched
Hope this works.
advantage cu Naicam.esj
(5.97 MiB) Downloaded 387 times
Al Navas
Post by Al Navas »
I downloaded the file and was able to reproduce the error exactly as described. In fact, I was able to reproduce it perfectly a total of five times. :lol: Even after this error, and without rebooting, I proceeded to remove all door and drawer pulls, one cabinet at a time.
Work-around: Removing all the drawer and door pulls eliminates this error, and also allows saving the job and working in the LDE. The entire job saved in less than 3 seconds.
Al
wayne chater
Re Workaround
Thanks Al, this may prove helpful. I'm reluctant to submit shop drawings to the archetect with no pulls but if it is the only way so be it. I may try developing the drawing without saving and then taking a jpeg or converting to a pdf file. My computer guru showed me how once before, now if only I can remember??? Tomorrow afternoon we leave for a week of house boating so I may not get to try this till I get back. I'll let you know how it works out.
Wayne
Al Navas
Post by Al Navas »
I am hoping it will work for you, Wayne.
While I was working with your file I noticed that memory use was pegged at the maximum of the physical memory on my laptop (2GB), before removing all the pulls.
Al
