Problem machining dovetail ***important***
DanFecteau
Post by DanFecteau »
I'm trying to run this dovetails file on the cnc and when it starts ok but in the middle of the program it stops and I get : \"INvalid syntax in program file\"
the line is : G01Z--0,0100F100.00
My guys are waiting for this job......
x.txt
twd file
(350 KiB) Downloaded 474 times
Dovetauks.esj
ecab file
(4.54 MiB) Downloaded 513 times
Justin Melhiser
Post by Justin Melhiser »
DanFecteau
The line of code you have is G01Z--0,0100F100.00
The line should read G01 Z-0.0100F100
Thank You
Justin
DanFecteau
yes
I already knew that Justin, but it does not solve anything, I'm not gonna change the 30 lines of code that are like that.......but I think I found the REASON that cause that, my skin thickness is set at 0,6 and my material is 0,597 so when it comes to machine any outline it crashes.
Justin Melhiser
Dan
I am looking at your files now. I will nest it and see if I ge tthe same error message as you. I will let you know as soon as I find out.
Thank You
Justin
