Batched drawer boxes
Zach Froble
Post by Zach Froble »
Is there a way to do a batch order of drawer boxes. If not it would be a nice feature.
Zach
Lyndan Designs
Machining and CAD Services
Zach,
Here is a method for batching doors described by Scott Vaal. This works great and he states that this method can be used for drawers also but I have not tried drawers yet. As he says in this post. follow the directions to the \"T\".
\"Kerry,
I don't know if you batch doors like this a lot, but here is a fast way to do it by creating one (as a cabinet without other parts) and then changing it to any size in the batch.
Follow these to the \"T\"
1.) Load the std base frame less.
2.) Delete all cabinet parts except the toe kick.
3.) Go to door/drawer editor: set the door you want default and then add it to the cabinet (do not change any door con-settings).
4.) Return to main.
5.) Go to con-settings -> toe kick tab: set the Height and Inset to zero, and uncheck \"Has Toe\", select OK.
6.) Save this cabinet and then batch any size/Qty door of this style that you want.
_________________
eCabinet Systems\"
