The motherboard inside our machine had died 2 days ago, so they send us a new one from Johannesburg and i replace it with the new now (identical). I fire up the control and everything works perfect, except the two usb ports on the side does not work. In device manager under usb controller i get the following errors: Intel 82801EB usb host controller-24d4 - This device connot find enough free resouces that it can use. I set the CMOS settings to the paper manual that was inside the machine(CMOS SETTINGS FOR THE ITOX ATX (G4C600) MOTHERBOARD.
Does anybody know how to fix this?
Thank very much in advance
There are four usb ports on the mother board but two of them are disabled on purpose. The two under the network card are the ones that should be disabled. That would be 24D4. These have to be disabled for the profibus card to work properly. Try using the other two usb's and see if they work properly. If you have any problems give us a call here at Thermwood 800-221-3865
