I have a client that lives in a 120 year old house that she inherited from her grand parents. She needs new counter tops in the kitchen, and has requested Cypress wood plank counters. Does anyone know if cypress is toxic? What kind of oil would you use for finish? She is aware that there is a possibility of warping, cracking and checking and she is ok with that.
Thanks in advance
Grady
To my knowledge the Cypress spurge (which is an herb) is the only Cypress that is poisonous. I believe this can also be found in North Carolina and surrounding areas.
\"Cypress spurge (Euphorbia cyparissias) is a naturalized herb found across southern Canada. Ingesting the plant has caused loss of cattle in New York State. This plant is usually avoided by livestock but is ingested if incorporated with hay. The plant is abundant in in some locations in southern Ontario. Some humans are sensitive to the irritant latex and may develop inflammation.\"
And here is the USDA data. This sheet shows toxicity as \"none.\"
Now to your other question on finish--something tough . Given the way we treat counter tops in our house, I just can't see using any type of wood, it would get pretty beat-up quickly
I did a set of Oak counter tops for a historical house in Aiken, SC. and we used Minwax for the stain, sealed that with lacquer sealer and used a resin top coat. This resin topcoat is the same thing used in bars and some tops in restaurants.
Oh, one last comment...be sure you have the customer sign a statement detailing their understanding of the problems that can arise with a wood counter top and the finish, including the (remote) possibility of it harboring bacteria and unknown toxicity.
Customers who \"understand all the potential problems\" are usually the first to develop amnesia when a pre-discussed problem arises.
Grady,
15yrs ago at the last shop I worked at, we used a lot of cypress for exterior work. 1yr. after building a house full of shutters we got a call from the owner, saying that the shutters were rotting. We never could find out if it was due to unknowing using sap wood or a possibility that kiln drying \"cooked\" the protective properties out of the wood.
What I hated about cypress, was that the grain has a tendency to \"lift \" and in hand sanding we would get a lot of splinters .
David Werkheiser
I just wanted to get the surface smoother to start with, because the decking was oak, This kept me from having to use so much resin. The customer wanted the gloss but didn't want that thick look of resin.
