Puzzle Piece Wasteboard
Greg Cannon
Post by Greg Cannon »
For what it's worth...
I haven't been able to find 5x10 material locally for wasteboard/spoilboard, but I have found 4x8 Ultralight MDF several places.
My solution: I copied the geometry from the \"puzzle piece face frame\" and created a DXF file that cuts and \"stitches\" together two 4x8 sheets into one 5x10 sheet.
It seems to work great and has the added advantage of allowing me to replace the corner most used for small parts independantly, if desired.
I found that a .25\" wasteboard had a tendency to curl after a few flycuts, so I flycut about .25\" off my spoilboard and now use .5\" (.471\" actually) material for the wasteboard. This allows me more flycuts to cleanup before I have to replace the wasteboard.
Rename the Outline layer to suit your material thickness.
The DXF files are attached. \"No warranty expressed or implied. :)\"
Enjoy.
WasteboardPuzzle.zip
Contains 3 DXF files that compose 1 complete wasteboard set.
(10.78 KiB) Downloaded 846 times
Brian Shannon
Post by Brian Shannon »
That's a cool idea Greg. I'm using a 3/8\" wasteboard now and I think it works better than 1/4\".
Brian Shannon
Hey Greg,
What part of O.C. are you in?
Brian Shannon
S.C.
Greg Cannon
I'm in Upland, CA, 91786.
Brian Shannon
Just curious. I'm from Orange. Originally.
