I need help with osbourne files
davidklehn
I cant fiqure how to download and then get into ecabs.please explain as if i am stupid.as i feel that way right now.need someone to walk me through it
- Damon Nabors
David, go to Osbournes web site. On the left side of the screen towards the bottom, you will see cad drawings. Click on cad drawings. You will then see a list of supported software companies, E-Cabinets is one of them. Click on e-cab. Fill in your info. Download to your desktop. Then right click the icon and extract the files. Now you are ready.
1. Go to the display parts editor ( looks like a red/green cup )
2. click the Load stl/hsf
3. choose directory Desktop
4. choose osbourne wood (or what ever you named it)
5. pick the part you want to use.
6. click save and save it under e-cab, import, and name it Osbourne wood products
7. Now you can click on the cabinet/assembly editor
8. rt click and choose load item
9. choose Display objects
10. You should see Osbourne wood (or what ever you named it)
11. Now your part should be there.
12. Now you can load your cabinet next to the display object ( you will have to move the globe, ctrl + arrow key)
13. after you load the cabinet, you can click the display object one time and turn it green then rt click, choose Match texture, then click the cabinet and your display part should change colors to match your cabinet.
Hope this helped
Hope this helped
davidklehn
