new to eCabinet and trouble with selecting nodes.
Eric Mattson
Post by Eric Mattson »
In the cabinet/assembly editor, after I load an item and select the parts associated with the align. I press (m) to locate my nodes. After I release (m) my nodes disappear. I move my pointer over the cabinet and loaded item all day and a node never highlights. I’ve tried zooming in, rotating, exploding, reading the manual, and still I can’t find my nodes when (m) is not depressed and I can’t select my nodes when (m) is depressed. Can someone tell me what I’m doing wrong? :?
Thanks, Eric
Eric Mattson
Scudder's Custom Cabinets and Solid Surfacing
129 Scudder Ln.
Searcy, AR. 72143
Joe Soto
Post by Joe Soto »
Eric, double click to select the parts, this gives a green out line not a mesh. Then hover over and you should see the nodes
Joe
Eric Mattson
Joe,
Thanks, that worked great. i knew it was something simple.
Eric
Eric Mattson
129 Scudder Ln.
Searcy, AR. 72143
Re: new to eCabinet and trouble with selecting nodes.
Pressing the M key will also show the nodes.
