Inset Carvings
Inset Carvings
Is there a folder with pictures of the inset carvings
or would I have to make one up :?:
I have an \"Inset Carvings\" directory but it is empty. The applied carvings are in C:\\Program Files\\Thermwood\\eCabinet Systems\\hardware\\Wood Component and either Adams Wood Components or Hafele.
Actually, the Inset Carvings directory has .csf files in it. I guess that is the extension for inset carvings.
George,
The Inset carvings are like selecting a tool in the part editor. You don't see the carving until you add it.
Highlight the part you want a carving on then right click and choose
Inset Carving Options/Add Carving
A window will open and you then click on the Add Carving button and pick a carving. but you don't see them until they load.
You can view the rental carvings in the Member Store and write down the number of the one you want then load that number in eCabinets.
Thank You Kerry and Dan
I tryed to put JPEG images in (Carving directory .csf files) it will not work.
I did not know where the carvings were now I know.
