Help please moving cabinet in detail room
Steve Dyches
Post by Steve Dyches »
I couldn't get the search engine to work this morning so, if anyone could help...
In custom layout/ detail room/ elevation view I'm trying to move a 2\" filler panel to a particular distance off the side wall. When I click on the filler and enter the value in one of the dimension fields (left or right) at the left of the screen it enters a value that is 19/32\" greater than what I typed. If I enter 36\" it displays 36 19/32\". 38\" gives me 38 19/32\", etc... Any ideas why?
Thanks in advance,
Steve
Justin Melhiser
Post by Justin Melhiser »
Steve
Please send me this job file, I would like to look at it and try it here. You can either post it or email it to me.
Steve,
I think your problem may be related to This Thread
Gene Kimmi
Post by Gene Kimmi »
Steve,
I run into this a lot. I have found the easiest solution is to enter the odd dimension into the move increment box for objects, in this case the 19/32, then hold the shift key and hit the arrow button for whichever direction you need the object to move.
Gene Kimmi
Lenovo W540 windows 8.1 Pro
Samsung 256 SSD Drive
Steve Dyches
Thanks guys,
Justin I have emailed you the job.
Kerry, I did look at that thread and it sounds just like my problem on a straight 120\"H wall. Regenerating it in the cabinet editor did not help.
I resorted to the incremental move.
Steve
Steve,
It is great that it will be fixed in 5.2
