Little quirk
Glenn Van Reason
Company Name: TBA
Country: AUSTRALIA
Little quirk
Post by Glenn Van Reason »
Just a little annoying thing, can the editors that are not able to be used in each section be greyed out so they can't be clicked. At present if your in say the shelf editor and hit edgebanding you get a pop up message saying you need to be in main to use.
I get use to \"if they are not greyed then they can be used\" mentality and hit them all the time.
Hear, hear!!!
Personally, I would like to be able to go from editor-to-editor without having to go back to \"Main\" first. Most editors appear to regenerate the cabinet after adding/editing components so its not like the trip back to Main is needed to regen everything.
In fact, I would like to see the regen happen only for the parts associated with a particular editor and a \"full regen\" only when you request it (click a regen button? function key? context (right-click) menu?).
Glenn Van Reason
Company Name: TBA
Country: AUSTRALIA
I can understand the complete regen, just in case what has changed is linked to something else, so that could stay, but even if you hit the button and it recognised that it needed a trip to main to regen then just do it automatically instead of getting us to do it maybe.
