While cutting dovetail drawer box's my machine sometimes stops while cutting the male pins. The spindle stays on but wont continue cutting until I press block stop plus and then run. I was running a series of test drawer box's and had this happen several times on one, once or twice on some and not at all on others. The only change I was making was to increase the dovetail bit diameter to tighten up the fit. I am using the standard, slide in drawer bottom, dovetail file. This stopping occurred mostly on the runs that were a very loose fit and went away when the fits were coming out better.
Has anyone else had this issue, and found a reason for this odd pause.
BTW, the drawer boxes are awesome. We had a client come in while I was working on this who was quite impressed. They were not aware that I was at the helm kicking the machine with block step plus to keep it cutting. I was able to get a great fit by adjusting the dovetail tool diameter and did not change any other settings. My final diameter for that tool is .367, though it measures .312 at the narrowest point of the cutting edges. Am I just lucky or is this a common way to adjust the fit of dovetails?
