Newbie question:
Can someone explain how "interpolate" and "maximum interpolate diameter" is used in nesting tool setup? What does this do?
I missed this one.
Steve Dyches
Interpolate Question
- Steve Dyches
Todd Miller
Re: Interpolate Question
Steve,Steve Dyches wrote:Newbie question:
I missed this one.
Steve Dyches
This is an paragraph copied out of the Control nesting manual located on the Thermwood website. Here is the link...
http://order.ecabinetsystems.com/update ... Manual.htm
These fields are grayed out until the operator chooses an operation type. Notice the “Interpolate” selection. With this selected, we are allowing that tool to be used for any circle interpolation that may be needed. Also, with this selected we are now able to set the “Max Interpolate Diameter” field. The “Max Interpolate Diameter” field allows the user to limit the size of hole to machine with that tool. Normally, when drilling a hole with a high RPM, there is a risk of burning the material or damaging the tool. Interpolating a hole will prevent this from happening.
