Mark,Mark Taylor wrote:I have a new client who needs a fairly large number of letters cut out of metal - at this moment I don't know exactly what kind of metal, but maybe aluminum or brass - 1/8 to 1/4" thick. Does anyone have any experience with cutting metal they could share. To date we have exclusively cut wood and a few acrylics - I know there are bits for cutting aluminum on the woodworkers supply - but I don't know if they need any special lubrication while cutting...etc. I would appreciate any responses/experiences to help me determine if this would be viable for us.
Mark
Mark Taylor wrote:Todd...thanks for your imput!
Question is the lubricating mister you referred to something that would attached to the spindle and produce a constant mist on the tooling or is it something hand held that would be applied - quote "as needed" throughout the cut?
There are probably more types than I know about. The misters we used were not programmable. We would just turn them on, then start the program, and let it cut. A lot of the aluminum samples we machined were held down by conventional vaccum directly on the 3/4" sealed MDF table or by using Double face tape. So the mist had no place to go, other than into the board. The board would swell and we couldn't use it anymore. Probably not what your looking for. Here is a link to WoodWeb that may give you more insight.Mark Taylor wrote:What type of coolant is the mister using - water or water based, or an oil type lubricant? Which presents another whole series of questions regarding amount of lubricant and it's collection?
Mark
