Is it possible to import ".x_t" parasolid file extenssions into eCab as a display item?
I remember reading a thread discussing this issue and can not find it.
Importing Parasolids?
Re: Importing Parasolids?
I just noticed several threads down there is a similar topic, I'll take a look at accutran 3d and see if it can convert it to .stl.
Parasolid files can only be used in the contour mode of part editor. You can bring in a display panel and then apply your parasolid file to that to give you your display part.
