Pomona show quest. about added scribe
Mark Fese
Post by Mark Fese »
Justin, At the pomona show I brought up the question of being able to add a certain amount of scribe to a cabinet stile and still be able to show the measurement of the anticipated finish dimension, Here in Beverly hills and Bel air there is no such thing as a scribe moulding we add 1/2" to are wall stiles enabling us to scribe the contour of the wall for a perfect fit, If the architect wants a 1 1/2" finished stile I will make it at 2" for scribe yet in the line drawing editor you can't show that 1 1/2" finished dimension which always gets back to me as a question during my red line process. Is there a way that you can come up with to allow us to create an 1 1/2" stile then mearly add scribe to it so we get an additional node to measure to? Thank's Mark Outlaw Carpenters 2009
Justin Melhiser
Re: Pomona show quest. about added scribe
Post by Justin Melhiser »
Mark
Here is something you can try. Load your cabinet, place the correct outside scribe on your 2" stile. Now take this stile to the part editor and make a notch in it. The notch should be no bigger that 1/2" in your part and about .010" thick. Example below. This will now give you the ability to measure to this node in the LDE. You can also add a note in the LDE to explain what you see.
Face Frame.JPG (6.27 KiB) Viewed 3023 times
Mark Fese
Post by Mark Fese »
Thank you Justin, I never thought of that and will give it a try on my next presentation. Mark.
Free Lance eCabinet Designers
ACD All Cabinet Design
www.acdallcabinetdesign.com
