Warm up Program
Thom Davies
Company Name: Dawn Group
Country: NEW ZEALAND
Warm up Program
Post by Thom Davies »
Hey Hows it going?
Im rewriting another warm up program for the themwood. (after i deleted by mistake!) And was wondering if there was a G or M code that does a timer? Like i want it 2 run for 15 mins then once the times up it returns home ready to run.
Thom Davies
Re: Warm up Program
Post by Ryan Hochgesang »
Hi Thom,
Yes, there is the Pause code which can simply pause the controller for the number of seconds you wish to pause.
G04F# (# = Seconds)
Once the number of seconds has been counted, the control will advance to the next line of code.
Michael J Starry
Re: Warm up Program
Post by Michael J Starry »
I make mine to ramp up as well. I run for 2 minutes each at 2000, 4000, 6000, 8000, 10,000 and 1 minute each at 14,000 and 18,000 RPM.
12 minutes warm up time allows my operators just enough time to do daily maintenance prior to running.
I also make sure the head is in the center of the table and halfway down the Z stroke which allows easy access to all grease zerks so maintenance can get done at the same time as the warm up.
I also have a grease/oiler program that runs all axis' over their full travel lengths for 15 minutes as well. I do this because not everything we cut has the machine extend to full travel, which means that the ways, rails screws and gears are not getting oiled/greased fully. Once per week I run all machines with this program to make. Looks a little silly having the machine run around itself, but it helps me know that there is lube on ALL parts that need it.
Will Williamson
Re: Warm up Program
Post by Will Williamson »
Michael
Would you be wiling to share that spindle warm up program and the exercise program to put the machine through its full range of motion ? I was thinking about just such a program the other day . I have a cs 45 510 I've only had my machine running for 3 months I supposethat I will eventualy be able to write my own program. My e mail is will@willmade.com
Thanks Will
Will
http://www.willmade.com
Thom Davies
Re: Warm up Program
Hey Michael
If you are willing to share the program could i get it as well please?
Email is: thermwood@dawngroup.co.nz
Thom Davies
Michael J Starry
Re: Warm up Program
I will get it to you guys early next week. Both the warm up and the oiler program. I am working from home today so I don't have access to them. But Monday or Tuesday I will get them out to you. Do you guys have 3 axis or 5 axis machines? I have programs for both.
Will Williamson
Re: Warm up Program
Hi Michael
Thank you. :D My machine is a 3 axis cs45 510 I hope I can repay the favor some day
thanks again Will Williamson
Will
Thom Davies
Re: Warm up Program
I have a 3 axis 1. CS-40
Mark Taylor
Re: Warm up Program
Post by Mark Taylor »
Michael,
I would certainly appreciate a copy of the programs as well.
our machine is a 3 axis CS45 510 as well.
Mark
mtaylor@handymansolution.com
Michael S Murray
Re: Warm up Program
Post by Michael S Murray »
ok, Michael, you satrted something here, I like your warm up program also, I have a cs45 5x10. I would appreciate that warm up if you dont mind. I am surprised that Thermwood doesnt include something like that?I usually just start the program and then hit the stop block button and let the spindle run 4 or 5 min. before it plunges to start cutting.
Mike Murray
mike@versatilecabinet.com
Terry Davis
Company Name: Penn Laminates
Re: Warm up Program
Post by Terry Davis »
Did I miss something at training? Why do you need a warm up program? As far as oiling goes ours oils to much, I'm always wiping oil off the machine sides.
Thom Davies
Re: Warm up Program
Can i just ask if this fantasic program is written in the evil imperial and i run it on a great metric set thermwood is it going to run ok? will it cause a prob?
Thom Davies
Thom Davies
Re: Warm up Program
Hey Terry.
The warm up program is to warm up the bearings on the router before you apply load. just like warming up a car and just like when we get out of bed in the morning! we dont start working hard out do we! lol I know i dont!
Cheers
Thom Davies
Michael J Starry
Re: Warm up Program
HERE IS THE WARM UP PROGRAM:
(PROGRAM - SPINDLE WARM UP ROUTINE)
(DATE - DEC-28-06)
G90
G00 X0. Y0. Z0.
(PICKS UP TOOL 2 AND RUNS FOR 10 MINUTES )
(GANTRY AND HEAD MOVE TO LOCATION TO ALLOW FOR GREASING)
S2000
T2 M03
G00 X30. Y30. Z5.0
M31
S2000
G04F100
S4000
G04F100
S8000
G04F100
S12000
G04F100
S18000
G04F100
S24000
G04F100
M05
G00 G45 Z
G43 (Tool Length Comp. Off)
G990
G00 X0. Y0.
G09F1
M49
M02
Thom Davies
Re: Warm up Program
Hey Thanks Mike.
Would it be poss if i could get the greese program aswell please?
Thanks heaps
Thom Davies
