Cutting 6mm Engineered stone
Neville Bastian
Post by Neville Bastian »
I am waiting for my c45 to be despatched but it comes with a mist spray. I think this is mainly for machining aluminium. Has anyone tried it on Engineered stone that is available in 6.5mm thickness. If you have, could you share your experience and what settings you got the best results with.
Thanks in advance
Regards
Neville
Neville Australia
Will Williamson
Re: Cutting 6mm Engineered stone
Post by Will Williamson »
Looks like you drew a blank. I see them discussing this sort of question a lot on the Art Cam forum
Will
http://www.willmade.com
Neville Bastian
Hi Will,
Looks like its not been done by any forum readers. I did see a sample done by someone here but they had the feed speed too high and the cutter was old. They didn't have any cooling either. It still cut it fairly well until the bit started melting. :) I have a Granite Transformations Franchise second business so am hoping I can do this cutting as it will save heaps of time.
I'll check out that artcam forum. I have downloaded that demo program so I should have a second look. I hope it has reverse plan ability as I wanted to draw it as required then flip it so I can rout from the back as you use 45 degree cutters for the face,seen edge. I don't think Ecabinets can flip at this stage.
Regards
Neville
Neville Australia
Will Williamson
Sounds interesting Let me know how you make out with this stone cutting as time goes on . My e mail is will@willmade.com Email me and as I run across these stone cutting articles I will forward them to you. Are these tiles that you are cutting?
Will
Neville Bastian
Hi Will,
The granite is actually like tiles but in the sheet format. There is some more info at this site if interested, http://www.granitetransformations.com.au/
The sheets are 3100 by 1300 so lend them selves to be cut like laminate. Currently we use Festo saws with a Diamond blade and that cuts well but slow and dusty.
On the Thermwood it would be a breeze as it could nest all the DXF's and away it goes. :P Well in theory at this early stage.
If you could keep me informed on ArtCams forum,thats great. I'll contact you on your email address soon
Regards
Neville
Neville Australia
