crashed profile modeler
Will Williamson
Post by Will Williamson »
HELP unable to retrieve profile modeler settings from registry
Will
http://www.willmade.com
Todd Miller
Re: crashed profile modeler
Post by Todd Miller »
Will Williamson wrote:HELP unable to retrieve profile modeler settings from registry
I think what happen is that you selected a default toolgroup that did not have any tools in it.
Cause:
Customer creates new Tool Group but does NOT put tools into the group. When the customer closes PM and reopens he gets an Error saying that the "Current Tool Group contains no tools. PM will revert to Default Tool Group." Then PM closes. At the point it is a continuous loop and will not allow you to enter PM .
Solution:
Close the THM software,
Start>Run>regedit>hkey local machine>software>THM>CADCUT>App-properties
Double-Click on "Tool Group", set "Value Data" to 0, Press OK.
Re-launch the THM software, go to the Profile Modeler and make sure a tool is assigned and saved to the Tool Group before closing PM.
If this does not fix the problem let me know.
Daniel Vonderheide
Post by Daniel Vonderheide »
Will,
I have sent you an email with the toolset.bin file attached. You will need to replace the original with this new file. It's stored in the "C:\profile modeler\tools\" directory. Let me know if you need anything else.
Daniel Odom
Post by Daniel Odom »
I'm having this same problem, can someone send me toolset.bin?
Will Williamson
Call tech support and they will email right away if you need it right now.
Will
Daniel Odom
Thanks I'll do that, I was hoping all I needed was a copy of a good file to get it back up. I don't really need profile modeling at the moment but it would be nice to get it fixed.
Daniel Odom
Ok, a combo of repair install and the above mentioned reg-edit seemed to do the trick, thanks.
