Moderators: Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein , Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein
Brian Shannon
Posts: 979 Joined: Thu, May 19 2005, 10:50PM
Post
by Brian Shannon » Mon, Apr 07 2008, 2:19PM
I need a little help from my friends. A client sent me this AutoCad DXF file to cut parts from 1/2" Plywood. I have never used a DXF file in RN. This DXF is set up @ 0 thickness and I tried to give it a .5 thickness in BobCad but really don't know what I am doing and it didn't work. Also, is there going to be a problem with the location of this DXF in relation to 0,0. Could someone please try and fix this file so that I can use it ? I know it is easy if you know what you're doing.
Brian
Mark Taylor
Posts: 309 Joined: Sat, Feb 04 2006, 5:13PM
Post
by Mark Taylor » Mon, Apr 07 2008, 8:20PM
Hi Brian....
Here is your file - I created an outline layer to be cut with .375 tool - reset the drawing to 0,0 and moved it to the outline layer.
You should be able to unzip it and send it straight to your machine. I apologize, I'm at home so I couldn't check it before sending it back.
Hope that helps
Mark
pew_sheet_layout.zip
(18.76 KiB) Downloaded 560 times
Brian Shannon
Post
by Brian Shannon » Mon, Apr 07 2008, 9:10PM
Thanks so much Mark! I'll give it a try in the morning.
Brian
Brian Shannon
Post
by Brian Shannon » Tue, Apr 08 2008, 5:19PM
Got'er done with the help of Mark Taylor and Joe Soto. Thanks Guys!
Brian
Mark Taylor
Post
by Mark Taylor » Tue, Apr 08 2008, 5:51PM
Mark
