Possible bug....or it could be me
Denis L'Heureux
Post by Denis L'Heureux »
I have this cabinet that I am trying to get the back inset 1/2".....this makes the back disappear completely. If I inset it .499" or .501 no problems....just not .5" This regardless of the back material I use.
If it is me, let me know so I beat my head on the wall a bit.
Cheers
Cabinet A834.01.esa
(436.02 KiB) Downloaded 412 times
Re: Possible bug....or it could be me
I can't do anything with cab1, cab 2 is fine. So I took a standard base framed seed and I could inset the back ok, so I tried a front inset on the fixed shelf and got a syntax error.
Denis L'Heureux
Cab 2 is only a toe kick and is fine (sort of). The main cab is the problem chile. I have tried removing face frame and all sort of stuff but nothing worked except changing the back inset for the back panel.
The gables and the stiles disappeared whenever I did anything to it.
Walker T Scott
Post by Walker T Scott »
This cabinet has issues from build 5.1. I have it listed for the programmers and will get back with you with what they find.
Denis L'Heureux
I will try and see if V5.2 does any thing good with it.
Tx for checking this out.
