Corner cabinets
Jean G Voyer
Corner cabinets
Post by Jean G Voyer »
I am trying to place those corner cabinets where they belong but they don't want to go.
Kitchen.esj
(1010.02 KiB) Downloaded 480 times
Jean-Gabriel Voyer
Janot Interiors Ltd
www.customcabinetscalgary.com
jerry johnson
Re: Corner cabinets
Post by jerry johnson »
Jean, you can get them where you want but you need to use weird left to right measurements like -11.5 or 12. stuff like that. It is a process of trial and error. I have had this same issue pop up from time to time and I have not figured out why it happens. Hope this helps. 8)
Jean G Voyer
Re: Corner cabinets
Thanks Jerry.
For me it never happened before. Only since I upgraded to 5.2.
Jean-Gabriel Voyer
Janot Interiors Ltd
Jean G Voyer
Re: Corner cabinets
Jerry,
I tried your negative number inputs but it still doesn't work. :wall: . I hope the programmers will look into it on Monday because I have a lot of designing to do and it's taking me backwards.
Jean-Gabriel Voyer
Janot Interiors Ltd
Jean G Voyer
Re: Corner cabinets
Sorry, it works OK if I revert to 'Free style'.
Jean-Gabriel Voyer
Janot Interiors Ltd
Re: Corner cabinets
Jean, the dimensions for the corner cabs are not showing up correctly, old or new jobs. Maybe as a quick fix you can go to the LDE and check your dimensions there. :|
Re: Corner cabinets
Jean, I deleted cabs 2 and 3 and saved cab 1 and it placed with align to back.I don't think assemblies place like cabinets. Check out this attachment. I place these in the room first at 0 height then cabs at 4".
Corner TK.hsf
(150.02 KiB) Downloaded 428 times
Jean G Voyer
Re: Corner cabinets
Rick,
What I did, I went to 'Free Style' and with the LDE I figured the dimensions and placed them without any troubles as assemblies.
The 'Align to back was creating all the fuss.
But thanks anyway. Your help is appreciated.
Jean-Gabriel Voyer
Janot Interiors Ltd
