sample_stls
Jean G Voyer
sample_stls
Post by Jean G Voyer »
Is it possible that the format of those files have changed?
I tried to use a slide in stove that I took from the forum and place it in that file for use on a job but it doesn't show up. And looking into the folder its format doesn't match the other objects.
What can I do to make it work?
Jean-Gabriel Voyer
Janot Interiors Ltd
www.customcabinetscalgary.com
Jean G Voyer
Re: sample_stls
I am just bringing it back to the front because I like to have an answer to this.
Jean-Gabriel Voyer
Janot Interiors Ltd
Scott G Vaal
Re: sample_stls
Post by Scott G Vaal »
Jean,
The format did not change for display objects. What extension does the file have? It should be ".hsf". If it is ".stl", then it must be taken into the Display Part Editor first, textured etc. then saved.
Did you save this file into a directory under the Import folder in the eCabinet Systems install directory? This is a requirement. If you still have issues, let me know which file you are trying to use and we can try it here. Hope this helps.
Jean G Voyer
Re: sample_stls
Scott,
This is the file I tried to use.
ge slide in range.zip
(206.5 KiB) Downloaded 386 times
Jean-Gabriel Voyer
Janot Interiors Ltd
Scott G Vaal
Re: sample_stls
Jean,
I unzipped it into a directory under Import and it loads ok for me. Did you unzip it??
Jean G Voyer
Re: sample_stls
Scott,
My mistake. I put it in the wrong file. :oops:
Thanks for straighten me up.
Jean-Gabriel Voyer
Janot Interiors Ltd
