Tooling Problem 2
leigh mills
Tooling Problem 2
Post by leigh mills »
Hi guys
I managed to sort out my tooling problem which I posted previously, to do this I had to change the tool slightly.
Anyway I have attached the new tool as I am now facing a different scenario, my tool works fine for a centre rout but I am having difficulties with the edge. I can do a 90° corner fine, but on some of our doors we have curves, the door I'm trying at the moment has a 4mm radius on all corners and my tool won’t work with this.
Can someone tell me if there is a way around this?
Leigh
Tool 1 Face & Edge Cutter 3mm - 6mm.tol
(7.3 KiB) Downloaded 350 times
Re: Tooling Problem 2
Hi Leigh, you should be able to select chain as a cutpath, and adjust your comp to place the bit where you like.
leigh mills
Hello Rick
I have just tried what you instructed and still have had no response from the tool.
