my question is when you use (build in house) for cabinet doors and drawers where do you find the lineal footage for it .
I cant find it in the cut list. Im i doing something wrong?
thanks for your help in advance
William, when you open the cut list there is a board stock summary which shows all of the board stock in the job. The problem I have had is the door stock is not separated from face frame stock, all the board stock is listed together. Also, I have not found where the board stock is listed for the drawer fronts if the are solid slab type. One thing I have done is to create a board stock with a different name than my face frame stock, i.e."red oak doors", and use that for the material when creating my doors and then the board stock summary will have both listed so you can separate the door stock from face frame stock. Hope this helps.
William
You can also export your cut list to excel and at the bottom of the page click on Board Stock Summary
and here you can see a list of Board stock in Inches. It will tell you how many inches of (1 1/4) ( 2 ) (2 1/2)( 3 ) ( 4 ) etc.
of board stock you need for this Job. But it Dose not tell Board feet. you will have to do a little math on it .What you see
on the board stock summary in the cut list is the total Board stock Counting the door and if you use 5 pice drawer front
but it dose not show slab drawer front and the best I can tell it dose not count for waste.
