This is new problem since 5.2 upgrade, when I add a door to a frameless cabinet setting top reveal 1/4, left 1/8, right 1/8, bottom 1/4 then add the door it shows and comes properly into the door editor, when I hover the mouse over the door it is the right size but when I return to the Main screen the door shrinks down another 1/4" leaving a 1/2" reveal at the top when I hover the mouse over the down it has shrunk by a 1/4". The is repeatable with any cabinet in any of my cabinet directories and when creating a new cabinet.
I just ran into this problem with a framed 45 deg. corner upper. I can load the cabinet into the editor, take it to the door editor and without making any changes to it, return to the main area and the doors change size. Here is the cabinet.
Terry
I if you remove the top two stretchers on the lower cabinet then go to the construction settings and change the top to top stretchers, make them both 4 inches like you want it will work. You will then have to remove the door and add a new one and when you return to the main cabinet editor the door will not resize.
Gene
I am working in V5.2B1. When I load you cabinet and go to the door and drawer editor, return to the main, my doors stay the same. Are you still in B5.1B3? If you are I would update to the V5.2B1. If you are in V5.2B1 then I will need some steps to help me recreate this.
I am working in5.2 also. When I load this cabinet, I go to the door editor and return to the main editor without doing anything else and the bottom door is 1 1/2" wider on the right side. It doesn't change until it rebuilds the doors after returning to the main editor. I have an upper corner assembly I am working on now that does the same thing.
Gene Kimmi
Lenovo W540 windows 8.1 Pro
Samsung 256 SSD Drive
We are aware of this issue. Sorry for the inconvenience. We plan to have a patch available to fix this. I can not give a time when the patch will be available yet, but know that we are working as diligently as possible. We appreciate your patience.
