Set the Settings and Preferences to show measurements in Inches and Fractions.
Open a standard cabinet in the Cabinet Editor.
Open the Self Editor
Open the Construction Settings dialog, then switch the the Adjustable Shelf settings. Since the shelf holes and spacing are usually set to metric values such as 5mm for the holes and 32mm for the spacing these values are wild looking (1969/10000), but accurate.
When you exit this dialog the software now complains about these values not being in 1/32 increments.
"Syntax Error: Fractions must be entered in 1/32 increments."
We are aware of this message. It is benign and it will be resolved in a patch due out soon. The “wild numbers” you speak of are nothing new and are that way by design in several fields. This is to maintain accuracy for fit and depth clearances and shelf pin hole diameters and spacing.
