Just got to love it!!! Again
Damon Nabors
Post by Damon Nabors »
I don't know what happened but it seems as though every cabinet I touch today has issues.
I was trying to use a corner cabinet that I use all the time and it would not resize for some reason or another???? So I built a new one and it resized correctly but I can not get the door to size properly. When I place the door on the cabinet in the door editor it looks ok, but when you go back to the main menu, the 1/2" overlay on the right side of the door goes away. It doesn't matter if it is a left or right hinge door.
I don't know what is happening but I go out of town for a couple of day's and come back. Now my cabinets that I have saved will not work properly. :wall:
Problem Cabinet 2.hsf
(644.02 KiB) Downloaded 235 times
Damon Nabors
Damon Nabors
Re: Just got to love it!!! Again
Here is another cabinet problem. How come if I use a standard corner cabinet with no angle the crown will not show up in a room? I have the left and right crown unchecked with overlap for the miter settings. When I bring the cabinet into the room the molding is not there. I can take the cabinet back into the cabinet editor from the room and the molding is still on the cabinet.
Standard Corner Upper.hsf
(642.02 KiB) Downloaded 241 times
Damon Nabors
Damon Nabors
Here is the room
Kitchen cabinets.esj
(4.66 MiB) Downloaded 250 times
Damon Nabors
Justin Melhiser
Post by Justin Melhiser »
Damon
Your standard upper corner cabinet, I can add it in a room and it has the molding on it. You might want to give me a call and we can go over these cabinets you have posted.
Justin Melhiser
Damon
We are aware of the moldings not showing up on the corner cabinet in the room. It has been fixed for the next patch.
Damon Nabors
Thanks Justin, Just got back into the office. I will try to place the moldings on manually and see if I can work around the problem.
Damon
Damon Nabors
