Vince Lisanti
Posts: 137 Joined: Sat, Jun 11 2005, 7:18AM
Post
by Vince Lisanti » Fri, Jun 06 2008, 9:27AM
I am having a problem with the cabinet below in the stretcher editor.
I can add the stretcher but when I go to adjust it all the numbers turn into -1 and everything goes whacky.
The stretcer I was working on was between the Top and Deck and was 3" wide.
The cabinet is actually a "Base Column End Panel" created in the Cab Editor.
Can someone else look at the file and tell me if it works for you?
BCEP_R_NoToeNotch.hsf
(248.02 KiB) Downloaded 331 times
Dell Precision M4800
32 GB RAM
NVIDIA Quadro K 2100M
Walker T Scott
Post
by Walker T Scott » Fri, Jun 06 2008, 9:49AM
Which insets are you changing and to what? Are you locking any insets? Are you rotating the stretcher?
I add a stretcher rotated it changed insets locked insets went to the main came back to adjust stretcher with no ill effect.
Vince Lisanti
Post
by Vince Lisanti » Fri, Jun 06 2008, 10:15AM
Walker,
I am using a 3" stretcher between the Top and Deck , front back orientation.
I want Inset 4 to be 3/4 " and inset 5 to be 0
But it does not work with any other insets either.
Vince
32 GB RAM
Walker T Scott
Post
by Walker T Scott » Fri, Jun 06 2008, 10:37AM
Do you have the rotation locked? If I uncheck it and change the insets I run in to problems.
Vince Lisanti
Post
by Vince Lisanti » Fri, Jun 06 2008, 1:40PM
Walker,
I re-booted the computer and now it seems to be working fine.
Vince
CCS
32 GB RAM
