Hi Guys,
When creating a display object such as a mirror or glass and selecting to appear on the cutlist, will this be blocked when sent to the machine?
Leigh Mills
Display Objects
leigh mills
- Kerry Fullington
Re: Display Objects
Leigh,
If you have a Display Object, it will not nest. If you have saved this Object as a Cut List Part, the cost you associate with this object will show up on the Cost Sheet but it won't be included in the nest.
If you use a Display Panel it will show up on the nest.
If you use a Display Board it will be in the cut list but not in the nest.
