delete display object
craig huzway
Post by craig huzway »
Hi all
how do you delete a display object from the place items / display objects list.
made some crappy ones in the early days and want them to go away.
deleted it in systems/import/sample hsf's but the picture is still in place items. get error msg. cant find it.
Todd Miller
Re: delete display object
Post by Todd Miller »
craig huzway wrote:Hi all
Files are located in the C:\Program Files\Thermwood\eCabinet Systems\import directory
Make sure you delete the .jpg image as well. Then restart the software. The image or the place where the image was should be gone.
craig huzway
thanks
didn't scroll down far enough. :beer:
Todd Miller
Craig,
Yes. Or you could select the part you want to delete and scroll down to the bottom of the dialog box and select "Delete selected items".
Justin Melhiser
Post by Justin Melhiser »
Craig
If you select the item you want to delete, when you scroll down to the "delete selected items", this will only delete the image. The file will still be located in the directory C:\programfiles\thermwood\ecabinetsystems\import. IF you want to delete it all together then delete it from the directory like Todd said, C:\Program Files\Thermwood\eCabinet Systems\import directory.
