Darren Harvey
Posts: 68 Joined: Fri, Jun 23 2006, 9:01AM
Post
by Darren Harvey » Mon, Jun 30 2008, 6:43AM
i finally got to really play with the new layout section. for some reason i can not adjust my casing in my door jams, or windows. also how do you go about putting a window in a door. thanks, darren
Posts: 4763 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Mon, Jun 30 2008, 7:14AM
Darren,
The only thing you can adjust about the passage doors and window casings is the texture.
To put a window in a passage or entry door you will have to cut a hole in your wall and create your own door and casing then place it in the hole,
