shelf question
Darren Harvey
shelf question
Post by Darren Harvey »
i'm working on a work table for a client. the question is that i need shelves on the front and back of the cabinets. i put a inset on the back to the distance i need. the front side of the work table is complete. now i need to basically need to copy to the other side. same hole pattern shelves, and partions. thanks darren
Justin Melhiser
Re: shelf question
Post by Justin Melhiser »
Darren
Send me what you have so far. I will look at it and advise you on what I think would be the best way to create the cabinet.
Jon Kenworthy
Company Name: darrells Carpenter Shop
Re: shelf question
Post by Jon Kenworthy »
I just had this problem and the way I went about it is to start the way that you said with the back inset, then take it into the part editor, make a line at the halfway point, then mirror the front part. Then you could double the shelves and partitions that you needed.
Center Island.jpg (22.68 KiB) Viewed 15347 times
Darren Harvey
Re: shelf question
thanks for the reply jon. darren
Thom Davies
Company Name: Dawn Group
Country: NEW ZEALAND
Re: shelf question
Post by Thom Davies »
WOW
Ok how do you do that mirror thing?
Jon Kenworthy
Re: shelf question
You set up a cabinet twice as deep as you need for the one side (for instance with a 3/4 in. back you could have a 48 in. deep cabinet which would equal two 23 and 5/8 in. deep cabinet). Then you put the appropriate inset on the back and put your shelves, etc. in the front side. Take the cabinet part into the part editor, then into the second screen of the part editor, create a line in the exact middle of the part, right click and select the Create Edges which will outline your adjustable shelf holes, etc. Then click on the mirror button and follow the on screen instructions to mirror the front around the line you created to the back of the cabinet part. Take the part back to the first screen of the part editor ,right click and select the cut/pocket option, and select the appropriate depth.
Darren Harvey
Re: shelf question
jon, i just tried the mirror tech. and i got it. thanks, darren
jerry johnson
Re: shelf question
Post by jerry johnson »
Thanks, Jon. I have been wondering how to copy adjustable shelf holes and this works great! 8)
Michael S Murray
Re: shelf question
Post by Michael S Murray »
What a good tip from a guy with only 2 posts.......Keep up the good work...
Mike Murray
mike@versatilecabinet.com
