How can you add new texture images? For example the lybary shows hardwood floor going vertical, but you would like it to go horizontal so it is more to what the client has in their home.
Also can you create new texture images, if so how do you go about doing this?
Thanks Gary
you can add any jpeg or bitmab file when you go to sellect the image for the flooring. There is a button at the botton left that is labeled "add image". Most of the files are only 100X100 pixels so you may want to crop out just a small section of a larger picture.
