I have a problem with a top that I do not remember having before.
I am using ver 5.2 build 2.
The problem is that I am trying to get the top flush with the back of the cabinet
and it is defaulted to the back flush with the top.
It works on the deck but not on the top. The area that you select that is greyed out.
In the top construction settings, the areas to select the left, right and top are all
greyed out but this is not the case with the deck. This problem has basically stoped
my production and I can't get it. I do not remember this in build 1.
Any ideas?
Gary Urlacher
Problem with top on upper
Gary Urlacher
Gary Urlacher
Re: Problem with top on upper
I found it. I had to set it to "mixed Flush" then it works.
Does any one know why this option is there for the top but not the deck?
Glenn Warner
- Company Name: Expressions in Wood
Looks like two different dialogs for accomplishing the same thing. May be an experiment to see what users like best or a friendly disagreement between developers.
Justin Melhiser
Gary and Glenn
The drop box with the flush options from the top settings will be removed so there won’t be any more confusion.
