I was reading the maintaince file on the controller and there was something about a grease program called grease.sp that could be found in the Data/Part file. I cant find it? How can i get it!
The program you are requesting is designed for usage when greasing Thermwood Turret style machines. When loading the program into THM interface and running it, the turret will rotate to each location and pause to let you grease the shotpin. If you have a turret style machine and need to get a copy of the original grease program for your machine, you can email: program@thermwood.com with your actual machine # and request this file.
