Currently when I add a countertop to a cabinet, I make the top shelf a different material that fit the specs that I need. Then I take the top to the parts editor and cut a hole for a sink. I am finding that I am repeating this process every time and it is time consuming.
Any words of advice? What is the best way to cut out for a sink, and is it possible to save this to be able to duplicate it relatively easily?
John,
If the cutout that you make is the same every time, it is relatively easy to save this and then re-use it later on.
Take one of your tops that you already cut out to the part editor. Go into contour mode and right-click, select the CreateEdges. This will create blue edge lines. Delete the ones that you don't want (typically the outside edges of the top). While still in contour mode, right click again and select Load Geometry. This option will then tell you that your profile pattern has changed, do you want to save it? Save this, as this is the one that you will later load again and use to make the cut-out.
NOTE: SAVE THIS IN A PLACE YOU WILL REMEMBER! It will save it in a Profile Tool Files format (*.x_t) After saving it, do not load any geometry (escape out of the loading option) Go out of contour mode and out of the part editor.
Now, take an unmodified top to the part editor and go into contour mode. Right click and load geometry. Do not save any profile patterns if it asks you to do so. It will then try to load a DXF file, but click on the drop-down and you will have a choice to pick *.x_t file type. Go to the directory where you previously saved the profile and click on it. Click on OK and you should have your profile loaded. You can then position it where you want and then exit out of contour mode and cut your pocket.
HTH
Aside from sink cut outs, do you use the countertop editor in the custom layout, or do you go a different direction?
I am currenly designing an office where there is only 1 cabinet under the desk top. What is the best way to make the top? The top goes into a corner where there is a 45 degree angle and then it extends out one side about 4'. I don't use the countertop editor because there aren't enough cabinets to attach it to. So I usually make up a display cube and cut it and profile the edge. Again,...is there a better way to do this?
