Desinging Doors
John J. Desmond
Desinging Doors
Post by John J. Desmond »
Here is a question for you ecab experts: At work this is how we create doors. Example: 12" door is figured this way;
Copeing depth in stile: .5"
Rail insert depth: .38"
difference for space balls: .125
We add the .125 space ball gap for both sides which is .25" to the overall length of the rail. Obviously this is what leaves the .125" gap on each side.
Finding rail length: 12" minus 4" (2" per stile which is distance after rail insert is subtracted).
So the rail length for a 12" door would be 8.25".
How do I get ecabs to figure my rail size? All I can find is cope depth and panel insert depth. I can't find a rail insert depth. If this is based on the copeing depth why am I getting the wrong rail size on my cut sheets?
ecabs also makes my stiles .125" to long. 38" door has stiles that read 38.125 on the cut sheet.
Can I change this or do I have learn a new way of doing doors? :?
John Desmond
Re: Desinging Doors
John, do you have your Perimeter Machining Allowance set to 0"? If it's set to 1/16" that would give you the extra 1/8" on the stile length.
Re: Designing Doors
John,
If your coping depth is 1/2" then your rail insert depth (which there is no place to set other than coping depth) will be 1/2". Coping Depth is the depth of the groove your cutters create in the stiles.
Adjust for your space balls in the Panel inset. If you want to allow 1/8" for the space balls using a 1/2" cope then set the panel inset at 3/8"
Check your machining allowance as Rick suggests also.
John J. Desmond
Re: Desinging Doors
Rick & Kerry,
Thanks to both of you for the input. Rick's advice worked. I had it set at 1/16". I am not sure how because I thought I had set it to 0. I am tempted to set it at 1/32" so that I will have an overall 1/16" oversize to allow for edge profile. I do have the panel inset set for 3/8" to allow for space balls.
Again, Thanks to you both.
Another quick question: Is it necessary to have a laptop for the ecabs seminars? I am really wanting to attend one (would be nice if one was closer). :wink: My laptop is not quite what ecab specs recommend.
John Desmond
Re: Desinging Doors
You do have to bring your own computer to the seminars. Thermwood provides computers for classes taught at Thermwood.
John J. Desmond
Re: Desinging Doors
Thanks Dan, I thought so. I hope to have a better laptop within a year. Maybe then?
Re: Desinging Doors
I have heard of a couple of folks lugging a desktop to a seminar. I don't think I would want to do that though. :wink: Of course you could put it on a cart and call it a "mobile workstation." :joker:
John J. Desmond
Re: Desinging Doors
I'm with you. I'm all for a mobile workstation. They are a bit pricey but the price is much lighter than the weight of a desktop.
Very funny. :joker:
John
Jeremy Schiffer
Re: Desinging Doors
Post by Jeremy Schiffer »
Check this out for a "mobile workstation" --
http://www.flixxy.com/fastra-gpu-supercomputer.htm
Pretty nifty!
CS-41 4x8
CS-45 5x12
Re: Desinging Doors
You can borrow mine if you want.
Re: Desinging Doors
Rick Palechuk wrote:You can borrow mine if you want.
I see it has its own generator too.
Re: Desinging Doors
Sweet eh.
