Pre Hung Doors
Thom Davies
Company Name: Dawn Group
Country: NEW ZEALAND
Pre Hung Doors
Post by Thom Davies »
How's it going?
Is there any1 who uses their Thermwood to door pre hung doors? I know we can do the hinges in the jambs easy enough. But can we do the hinges in the door it self? I have a CS40 so its only a 3 axis. Is there an attachment or tool that we could buy to do the door hinge?
Thom Davies
Nick M Singer
Re: Pre Hung Doors
Post by Nick M Singer »
Hi Thom. The answer is yes, there is a right angle holder which would allow you to machine the door edge. You would probably also have to raise the door up off the table using vacuum pods or some such
Thom Davies
Re: Pre Hung Doors
Cool
How much does it cost and where can i get 1? what do i have to do @ the machine to get it working?
Thom Davies
Re: Pre Hung Doors
Can some 1 from thermwood give me an idea how much this right angle tool costs? and is it a drill bank tool or a router tool?
Thom Davies
Daniel Vonderheide
Re: Pre Hung Doors
Post by Daniel Vonderheide »
Thom,
You need to contact Dan Lopez at 1-800-221-3865. He will be able to quote you a price on retrofitting either a drill bank with horizontal drills or a horizontal aggregate tool.
Will Williamson
Re: Pre Hung Doors
Post by Will Williamson »
Daniel
Once these tool are setup How do you program them? Manual ? Mastercam? Or should I ask what is the best way to program them?
Thanks Will
Will
http://www.willmade.com
Daniel Vonderheide
Re: Pre Hung Doors
Both mastercam and manual programming will work well for these types of operations. Which is better depends on your personal preference and the doors. If you do alot of doors where the dimensions never change then mastercam can create the file once and you never mess with it. If the door dimensions are always changing and you need flexability, you may want to look into doing a program in AFL that asks for dimensions and pocket offsets and then it calculates it's own positioning.
