Posts: 1896 Joined: Wed, May 18 2005, 7:54PM
Post
by Rick Palechuk » Thu, Aug 28 2008, 6:43PM
The system is not allowing me to edgeband the deck on this cab.
Any idea's?
Tall Closet TV.hsf
(692.02 KiB) Downloaded 743 times
Damon Nabors
Posts: 923 Joined: Wed, Apr 05 2006, 5:50PM
Post
by Damon Nabors » Thu, Aug 28 2008, 7:27PM
Rick, here is your cabinet w/edgebanding.
Damon
Tall Closet TV.hsf
(692.02 KiB) Downloaded 794 times
Damon Nabors
Post
by Rick Palechuk » Thu, Aug 28 2008, 8:44PM
What ya do?
Damon Nabors
Post
by Damon Nabors » Thu, Aug 28 2008, 9:32PM
deleted the toe kick and the deck. Reloaded the deck. Applied the edgebanding and then reloaded the toe kick. It would not take the edgebanding as long as the toe kick was there. I ran into a problem like this the other day but finally got it to work.
Sorry, I didn't explain earlier, the wife was informing me that I needed to get off the computer. Imagine that!
Damon
Damon Nabors
Post
by Rick Palechuk » Thu, Aug 28 2008, 9:47PM
I get that issue sometimes too.
Damon Nabors
Post
by Damon Nabors » Fri, Aug 29 2008, 7:03AM
Rick, I am working on a large edgebanding job myself and this edge banding thing is all new to me since we normally only do FF cabs.
I guess you can not edge band a stretcher??? I noticed that stretchers do not show up on the list.
Damon
Damon Nabors
Post
by Rick Palechuk » Sat, Aug 30 2008, 1:33AM
I use a fixed shelf with a back inset instead of a stretcher.
Damon Nabors
Post
by Damon Nabors » Sat, Aug 30 2008, 6:37AM
I have never tried it, but if I understand you correct, your saying you can rotate a shelf into position to act as a toe kick, or toe board??
Damon Nabors
Post
by Rick Palechuk » Sat, Aug 30 2008, 8:03PM
No, you can't rotate a shelf. In frameless, a stretcher is commonly used between drawer openings.
Damon Nabors
Post
by Damon Nabors » Sat, Aug 30 2008, 8:10PM
My bad, I thought you was talking about the toekick. I know what you are talking about with the shelf. I used one like that the other day. I guess you got everything worked out and ready to cut now.
Good luck,
Damon
Damon Nabors
Post
by Rick Palechuk » Sun, Aug 31 2008, 7:54PM
Yes, we are sending this job out for a price on getting it cut.
Walker T Scott
Post
by Walker T Scott » Wed, Sep 03 2008, 12:59PM
I’ve been looking at your cabinet Rick and the front construction on the deck is blank in the construction settings. If you change it to butt and press ok you should be good to go. Do you or Damon know what you did to get this to happen I can’t reproduce this?
Post
by Rick Palechuk » Wed, Sep 03 2008, 2:26PM
I will try and reproduce it Walker.
Damon Nabors
Post
by Damon Nabors » Wed, Sep 03 2008, 3:11PM
Walker, I don't recall looking to see if BUTT was checked or not, but the deck did not show up in the edge banding list. I had to delete the deck and add it back in order to get the deck edgebanding to show up on the list of parts to be edgebanded.
Damon
Damon Nabors
Damon Nabors
Post
by Damon Nabors » Wed, Sep 03 2008, 3:47PM
That worked pretty good also Walker, the front edge of the deck was blank on my screen but I changed it to Butt and everything works ok.
I guess we need to dbl check and then dbl check again.
Damon Nabors
