Angle Snap
- Gary Puckett
Angle Snap
Can anybody explain how to use angle snap?
Re: Angle Snap
Hey Gary, in Contour mode if you want to draw a line to a known angle just enter the amount, and the line will only snap to that degree.
- Gary Puckett
Re: Angle Snap
Thanks Rick
- Damon Nabors
Re: Angle Snap
One thing you might want to keep in mind. It will not snap a 1/2 degree like 22.5. So your measurments will not be exact if you try this.
Damon
Damon
Damon Nabors
Re: Angle Snap
I think that might work now Damon, I just tried 90.5 and the line snapped askew.
- Damon Nabors
Re: Angle Snap
I think it will snap the line but it will not be correct, That is unless they have fixed it. I have a hard time keeping up with what is working and what is not working. Maybe Dennis or someone will chime in this morning and give us an update.
Damon Nabors
- Damon Nabors
Re: Angle Snap
Re: Need an angled lower!
by Dan Voges on Fri, May 02 2008, 6:46AM
You aren't imagining things. eCab will not do design on the 1/10th degree. When you try to design with a 22.5 degree angle snap, it is round it to the nearest whole number, 23. This is something that is pertinent in the Contour Mode of Part Editor, as well as Shape Manager. This can easily be overcome by designing the angle you want in AutoCAD or some other CAD system, and importing that as a DXF onto your part or into Shape manager as a tool (for designing tools that miter). When you do that way, it does indeed machine out as a 22.5 degree angle.Dan Voges
Thermwood Corp.
Training InstructorDan Voges
Private message
This was a response to my finding this out in May of this year. I hope they get it fixed but for now I am able to draw it up in another program when needed.
Thermwood Corp.
Private message
Damon Nabors
Re: Angle Snap
I do remember the post. Short of digging out the slide rule
and checking the angle of the dangle
it seemed odd that with only the angle snap on, set at 90.5, it would snap askew
. Yes Cad is the way to go.
Re: Angle Snap
Second cup of coffee...Does it draw correctly, yet machine to the whole number?
- Damon Nabors
Re: Angle Snap
It will cut the angle wrong. I cut some templates one day to set some angled cabinets and found the numbers to be off when placing the counter tops on the cabs. The counters were 22.5 deg. and my cabs got set at 46 deg.
Damon Nabors
Re: Angle Snap
A 22 1/2 degree line can be drawn in eCabinets in an indirect manner. There is a full explanation of this in "The Nearly Complete Guide to eCabinet Systems", but the short of it is:
For example,
1. Create a horizontal line and a 45 degee line that are of equal length that intersect at one end.
2. Draw a circle at the open end of each line. The circles should overlap.
3. Trim the circles so that have only the nearly elliptical or football shape remaining.
4. Draw a line from the intersection of the 45 degree lines through the endpoints of the arc.
You should have successfully split the two lines and now have a 22 1/2 degree line.
This method comes from the old mechanical drafting (pencil) techniques.
So while a CAD system does have more tools and capabilities, a lot can still be accomplished without making that purchase, particularly if you are on a budget.
Dennis L. Englert
For example,
Dennis L. Englert
