Deleting an image
- Gary Puckett
Deleting an image
I can't get images in the material lybary to delete. I pull it up high light it hit delete an nothing, it's still there.
What am I doing wrong?
Todd Miller
Re: Deleting an image
Gary,Gary Puckett wrote:I can't get images in the material lybary to delete. I pull it up high light it hit delete an nothing, it's still there.
Where are you trying to delete them from? The define materials area or...? Do you get any errors when trying to do this? Let me know.
- Gary Puckett
Todd,
In define stock material, I get no error but it does not delete the image
THanks
THanks
Todd Miller
Gary,
Are you hitting the delete button in the upper right hand corner of the dialog box or are you using the delete key on your keyboard? The delete key on your keyboard does not work for this action.
Todd Miller
Gary,
Are you trying to delete the images from the "Select images" screen? If so you will not be able to delete any file loaded originally with ecabs. That is unless you go into the C:\Program Files\Thermwood\eCabinet Systems\materials directory and delet them there. FYI
- Gary Puckett
Todd,
This is an image that I put in and now want to delete it. I hit the delete image button an it flashes but does not delete.
Todd Miller
Gary,
Go into the C:\Program Files\Thermwood\eCabinet Systems\materials directory and delete them there.
- Gary Puckett
Thanks Todd,
That worked.
That worked.
