LDE Problem
Damon Nabors
LDE Problem
Post by Damon Nabors »
Can someone download this cabinet and see if it acts the same way on your computer. If I take this cabinet into the LDE, and then try to rotate the cabinet so I can get a measurment from the side, the rotate funtion acts crazy. Then if you go back into the cabinet editor, you get a box where the rotate dialog box would have been in the LDE.
It worked one time for me and now it will not work. I have gone back and deleted all my changes and it still will not work. :?
Damon
W0912L.hsf
(290.02 KiB) Downloaded 267 times
LDE Problem.jpg (134.29 KiB) Viewed 2724 times
Damon Nabors
Damon Nabors
Re: LDE Problem
Another crazy thing, if you click "NEW" to get a new cabinet to start over, The cabinet goes away but the LDE box continues to stay there. :wall: :wall: :wall:
Damon Nabors
Re: LDE Problem
Everything seems to be ok for me so far. Try restarting your rig see if that helps.
Damon Nabors
Re: LDE Problem
Thanks Rick, I rebooted the system and it works ok for the moment. Not sure what happened.
Damon Nabors
