Hi
I have a door that I have created from the left end of a cabinet. I have applied 4 hinges holes with a saved profile. I am now scratching my head as to how to constain the two middle hinge holes. My top and bottom hinges are always to remain 98mm from the edge and the two middle hinges are to remain evenly spaced between these two.
How can I write a formula that when I change the height of the door these two middle hinge holes will remain evenly spaced between the top and bottom hinge holes? I'm assuming its something like, H/3+98 or something. I'm not sure whether I am on the right path here or even if I have to write the formula in a specific way. I will attach the cabinet file. I did read up on this in the manual but it didn't go into depth as to any programing language that must be used. + - / * ( )
Close Dale, the formula should be (H+98mm)/3 (see my test below...it is in inches but same concept). Yours had so many constraints it was easier for me to test with a simpler design.
Door Test Constraints.jpg (22.04 KiB) Viewed 3660 times
